temp-ani.gif only has 2 frames?
hmboy
Hi guys, it appears that my temp-ani.gif only has 2 frames.. This is shown in both the lcd and on the pc.
It should have more then 2, like a thermometer, going to the top..
Anyone else having this problem? (i saw a previous post had a preview of gifs and it had the full one but that was oversized for use in cc2)
I presume that this is my animation from the User Library? It has 7 frames. Check your screen file. The gif part probably looks something like:
[from00]
from="cc2_showgif.ini"
sec="gif-#"
opt09="start=1"
opt10="end=2"
Change the opt10="end=2" to opt10="end=7"
Should work then.
hmboy
but all instances of the gif only show 2 frames when i view the gif on my pc ...
i am running vista, but i think this used to happen on xp too...
can you upload a good version of the gif?
Try this one. Guaranteed 7 frames.
hmboy
im looking at that from work, and its exactly the same, its only showing the first 2 frames, this is on windows 2000/internet explorer.
Add it to a screen file. I just did and it works fine.
For whatever reason, explorer is not showing it correctly.
