Shuttle SN25p & Speedfan (631 only)
knowley
These screens are only for Shuttle SN25p users who have installed installed using VillageIdiots configuration file from http://www.almico.com/sfhandleconfig.php.
I only installed this my 631 this morning, and discovered the old Crystal Control software and MBM do not work with the Shuttle SN25p. So I got hold of Crystal Control 2 and Speedfan. The users at http://www.sfftech.com/ speak very highly of Speedfan and VillageIdiots config file is widely used.
Unfortunately the tempreature and fans you want to monitor aren't the first four in the Speedfan config. So I had to "hack" and "tweak" the Speedfan files issued with the Crystal Fontz software with a little help from reider's posts where he's explored all 32 temp and fan sensors.
So big thanks to both reider and villageidiot!
N.B. I can't guarantee these files are 100% correct & bug free - this is after all my first attempt!
Speedfan http://www.almico.com/speedfan.php
villageidiot - http://forums.sudhian.com/messageview.aspx?catid=43&threadid=83648
reider - https://forum.crystalfontz.com/member.php?s=&action=getinfo&userid=1971
  • sn25p_631screens.zip
knowley
Oh yeah, and if someone can tell me how to make text scroll then I'll be able to make them look a bit nicer :D
Example for a line:
[r00-i02]
length=11
options=10
string="Whatever"
will scroll "whatever" within a space of 11 characters. The key is the options=10.
knowley
I've done a couple, but would like the scoller to be slower/smoother...
Is there any documentation on the settings and options that can be put in these screen files?
  • sn25p_scrollers.zip
Another example:
[r00-i00]
options=10
length=7
scroll_speed=1000
string="CPU"
I am not sure if 1000 is the default. Try that and adjust as desired.
