Riva Tuner Temps & Fan graph
knowley
I've edited the Riva Tuner temps screen to show the two temps on the first line and a bar graph for the fan speed on the second line. Not sure what I've done wrong but as soon as I added the graph the degrees character (o) has turned into a solid block...
Thanks :confused:
  • rivatuner temp & fans.zip
Can't have both cc2_cchar.ini and cc2_hbar.ini in the same screen.
Use the \128 variation:
string="\128C" = degree symbol C
That will work.
knowley
Ahh nice one thanks!
Why use the cc2_cchar.ini at all?
And can't you use two inis generally or is it just those two?
Both use the "custom character" buffer. Gif files use the same buffer, also.
I am not sure if that is the technical term, but this buffer is a limitation of LCD electronics.
And BTW, I rarely use the cc2_cchar.ini anymore.
