PIN UP QUESTION 240x128 GRAPHIC LCD
ALEX5657
:d
hello
i wanna know how can i connect frame ground? What is the function of that pin?
And what is the function of chip enable?
Alex
The frame ground generally connects to the mounting holes, and perhaps the bezel tabs, depending on the display.
What is the part number of the display you are using?
CF Support2
Here is a table that should help in the functions of the CFAG240128L Pint out.
  • G240128L_Pin_out_detail.pdf
