PIC16F874a with CFAH0802D
robby991
Hi, I am trying to initialize a CFAH0802D using a PIC16F874a Hi tech C compiler in MP Lab, however I can only get the top row of boxes to light up. There seems to be an issue with my initialization routine. I attached my code, along with the schematic of my setup. I have added various delays in between commands to see if that will help, but it hasn't. If anyone has any suggestions, please let me know. Thanks.
my main is
#include <pic.h>
#include "htc.h"
#include <stdio.h>
#include "LCD.h"
#include "delay.h"
#define _XTAL_FREQ 3580420
__CONFIG(FOSC_XT & WDTE_OFF& PWRTE_OFF & BOREN_OFF & LVP_OFF & WRT_OFF & DEBUG_ON & CPD_OFF & CP_OFF);
 main()
	lcd_clear();
	lcd_init();
	__delay_ms(500);
	lcd_puts("test");
		for(;;);
And LCD.c, where initialization is
 *	LCD interface example
 *	Uses routines from delay.c
 *	This code will interface to a standard LCD controller
 *	like the Hitachi HD44780. It uses it in 4 bit mode, with
 *	the hardware connected as follows (the standard 14 pin
 *	LCD connector is used):
 *	PORTD bits 0-3 are connected to the LCD data bits 4-7 (high nibble)
 *	PORTA bit 3 is connected to the LCD RS input (register select)
 *	PORTA bit 1 is connected to the LCD EN bit (enable)
 *	To use these routines, set up the port I/O (TRISA, TRISD) then
 *	call lcd_init(), then other routines as required.
#ifndef _XTAL_FREQ
 // Unless specified elsewhere, 4MHz system frequency is assumed
#endif
#include	<htc.h>
#include	"lcd.h"
#define	LCD_RS RA3
#define	LCD_RW RA2
#define LCD_EN RA1
#define LCD_DATA	PORTD
#define	LCD_STROBE()	((LCD_EN = 1),(LCD_EN=0))
/* write a byte to the LCD in 4 bit mode */
void
lcd_write(unsigned char c)
	__delay_us(40);
	LCD_DATA = ( ( c >> 4 ) & 0x0F );
	LCD_STROBE();
	LCD_DATA = ( c & 0x0F );
	LCD_STROBE();
 * 	Clear and home the LCD
void
lcd_clear(void)
	LCD_RS = 0;
	lcd_write(0x1);
	__delay_ms(2);
/* write a string of chars to the LCD */
void
lcd_puts(const char * s)
	LCD_RS = 1;	// write characters
	while(*s)
		lcd_write(*s++);
/* write one character to the LCD */
void
lcd_putch(char c)
	lcd_write( c );
 * Go to the specified position
void
lcd_goto(unsigned char pos)
	LCD_RS = 0;
	lcd_write(0x80+pos);
/* initialise the LCD - put into 4 bit mode */
void
lcd_init()
	char init_value;
	ADCON1 = 0x06;	// Disable analog pins on PORTA
	init_value = 0x3;
	TRISA=0;
	TRISD=0;
	LCD_RS = 0;
	LCD_EN = 0;
	LCD_RW = 0;
	__delay_ms(500);	// wait 15mSec after power applied, changed from 5ms
	LCD_DATA	 = init_value;
	LCD_STROBE();
	__delay_ms(500);  //changed from 5ms
	LCD_STROBE();
	__delay_us(500); //changed from 200
	LCD_STROBE();
	LCD_DATA = 2;	// Four bit mode
	LCD_STROBE();
	lcd_write(0x28); // Set interface length
	lcd_write(0xF); // Display On, Cursor On, Cursor Blink
	lcd_clear();	// Clear screen
	lcd_write(0x6); // Set entry Mode
Character LCD Modules
