CrystalControl2 - 31/03/09
Status
Not open for further replies.
CrystalControl2 - 31/03/2009
Note: This release of CrystalControl2 has had very limited amounts of beta testing, and it is quite likely a few bugs exist. If you have problems, please report them in the forum.
Version History:
31/03/2008:
- Fixed 631/633/635 fan/temp reporting bug
26/03/2008:
- Fixed HD44780 setup issues
- Added SimBin plugin (GTR, GTR2, Race, Race07, GT Legends, GTR-Evolution support)
- Fixed possible 631/633/635 fan packet handling bug
03/04/2008:
- New rFactor plugin
12/08/2007:
- New Rivatuner plugins
- Fixed E01's in email plugin
20/07/2007:
- Tweaked timing routines.
- Many more small fixes.
25/12/2006:
- New Screen-Editor!
- Screen transition effects!
- New plugins.
- Lots of bug fixes.
25/03/2006:
- Fixed empty string INI bug.
- New kill_cc2 utility.
26/02/2006:
16/02/2006:
- Added user idle LCD dimming
- New screens
- Fixed screen loading bugs
- Added simple calc plugin
- Fixed many misc bugs
- New screens
- Manual updates
- New loadable screens
- Now supports item scrolling
- Many other smaller things
- First public release
The most recent release of CC2 does not include the normal screen files.
My apologies, it was an oversight when creating the release installation file.
Attached is a ZIP file containing the screen files.
Extract them into your "CrystalControl2\screens" directory.
  • cc2_screens.zip
Attached is a ZIP file containing a textfile2 plugin update a few Twitter RSS feed screens.
To use the new Twitter screens:
1 - Stop CrystalControl2
2 - Extract the files from the ZIP
3 - Copy the textfile2 plugin file into your CrystalControl2 directory
4 - Copy the screen files into your CrystalControl2\screen directory
5 - Restart CrystalControl2
6 - Load the screen files in the Screen Editor.
Note: The username and password you enter for Twitter will be stored in plain text (non-encrypted) in your CrystalControl2 setup files.
If you are concerned about security, do not use these screen files.
  • twitter_update.zip
Status
