CrystalControl2 - 20061225 (Merry Christmas)
Status
Not open for further replies.
CrystalControl2 - 25/12/2006
Merry Christmas Everyone!
My Christmas present to all of you... the Screen Editor is finally here!
A big THANKYOU to the beta testing team who have made this possible.
It is recommended that you uninstall older versions of CrystalControl2 before installing this new version.
Not doing so may cause problems.
Version History:
25/12/2006:
- New Screen-Editor!
- Screen transition effects!
- New plugins.
- Lots of bug fixes.
25/03/2006:
- Fixed empty string INI bug.
- New kill_cc2 utility.
26/02/2006:
16/02/2006:
- Added user idle LCD dimming
- New screens
- Fixed screen loading bugs
- Added simple calc plugin
- Fixed many misc bugs
- New screens
- Manual updates
- New loadable screens
- Now supports item scrolling
- Many other smaller things
- First public release
See below for updates for this release
- None as yet.
Attached is an updated Foobar200 plugin that will work with more recent versions of the music player.
The file is a self-extracting archive, run it and copy the extracted DLL into your foobar2000\components directory.
  • foo_crystalcontrol2_09.exe
Status
