CrystalControl2 - 20060325
Status
Not open for further replies.
CrystalControl2 - 25/03/2006
It is recommended that you uninstall older versions of CrystalControl2 before installing this new version.
Not doing so may cause problems.
Version History:
25/03/2006:
- Fixed empty string INI bug.
- New kill_cc2 utility.
26/02/2006:
16/02/2006:
- Added user idle LCD dimming
- New screens
- Fixed screen loading bugs
- Added simple calc plugin
- Fixed many misc bugs
- New screens
- Manual updates
- New loadable screens
- Now supports item scrolling
- Many other smaller things
- First public release
See below for updates for this release
- 633 Plugin Update
633 Module Plugin Update.
This update fixes 633 contrast control problems.
Stop CrystalControl2 and then copy this new plugin into your CrystalControl2 directory overwriting the old file.
  • lcd_633.dll
Status
