CrystalControl2 - 20060226
Status
Not open for further replies.
CrystalControl2 - 26/02/2006
It is recommended that you uninstall older versions of CrystalControl2 before installing this new version!
Not doing so will cause problems.
Version History:
26/02/2006:
16/02/2006:
- Added user idle LCD dimming
- New screens
- Fixed screen loading bugs
- Added simple calc plugin
- Fixed many misc bugs
- New screens
- Manual updates
- New loadable screens
- Now supports item scrolling
- Many other smaller things
- First public release
See below for updates for this release
- RivaTuner plugin update.
Update: RivaTuner plugin problems
The RivaTuner plugin supplied with this release of CC2 doesnt not work correctly and reports [E01]'s.
To fix this, stop CrystalControl2 and copy the attached file into the your CrystalControl2 directory overwriting the old one.
  • cc2_rivatuner.dll
Status
