I am trying to POWER ON/OFF the system using CFA633 but this feature is not working. I am using Tyan's S5201 motherboard which doesn't have any WOL header onbaord so I am pulling +5v STBY directly from power supply.
When I hold the power ON button on CFA633, the display on LCD screen comes up for a second displaying CrystalFontz FW version but it doesn't turn on the system. The display goes off after a second or so. I had tried to swap the single wire that has to be connected to motherboard power ON switch. I get above behavior when single wire is connected to POWER ON pin, but if I connect the same wire to GROUND pin and press the power ON button, that turns on the system but the system automatically turn itself off after 4-5 seconds.
Can anybody help me out with this problem ?
BTW, reset function works fine.
Appriciate your help...
