I have an old CFA633 (v1.5a) that I've repurposed for a new project. It was configured to operate in ATX power mode for an older motherboard (Supermicro P4SCI), and it appeared to work.
Since upgrading the board, I've been unable to replicate this.
With the power and reset wires connected to the motherboard, the moment I connect power, the system powers up. I can hold down the X key until the module reads POWER OFF, but the system is never shut down, and the CFA633 stays in this state until a reset is issued by holding down the check button. The reset function resets both the CFA633 and the system, as expected.
Jumper jp8 is open and jp9 is closed, as per the data sheet. According to the output returned by command 30, the bits KEYPAD_POWER_OFF, KEYPAS_POWER_ON, KEYPAD_RESET, LCD_OFF_IF_HOST_IS_OFF, and POWER_INVERT are active (RESET_INVERT is not). I've tried changing the setting of POWER_INVERT to no avail - no matter what, I cannot power this system off without pulling the power cable. Even a shutdown from the OS (Linux) sees the power turn off briefly... and then come back on. When connected to a normal switch, powering off behaves as expected.
Any ideas on what I'm doing wrong?
