We have a bunch of new 533's (CFA533YYHKS) that we are testing out as replacements for 633's. We are seeing an issue with the 533s where they receive commands from applications, but don't send responses correctly. Some of them don't seem to transmit at all (key presses or in response to ping, version request,e tc.) and some seem to occasionally send a keypress report, although at a less than 20% recogition rate.
We know they are receiving commands correctly, since we can see data on the display, clear the display, change the backlight, etc.
We have tried this with a number of applications that we have written for the 633s and saw the behavior. We have also recreated it with the linux command line example code. We have tried the units at the default 19200 and also switched them for operation at 115200 with the same results.
We have also tried several different hardware configurations, to make sure it isn't a cabling issue (including swapping in a 5V modified (by CF) 633. All the other displays work as advertised.
Any ideas?
Any ideas?
