cc2_tray.exe constantly writing stats log
moeburn
I finally found why cc2_tray.exe has the highest cpu-time usage out of all my system processes. It is because once every 2 seconds, it opens c:\programdata\CrystalControl2\stats-633-349571245.txt , writes to it, and closes it. But it is writing the EXACT SAME DATA EVERY 2 SECONDS!
This is the data that CC2 feels it must write:
01/07/2013 12:47:32
CFA633 HW1.5 FW1.9
FANS:
sensor,name,power,power-min,power-max,auto-ctrl,auto-power,manual-power,avgtemp,avgtemp-min,avgtemp-max,rpm,rpm-min,rpm-max
fan01,Fan 01,100,100,100,0,100,100,NA,NA,NA,0,0,0
fan02,Fan 02,100,100,100,0,100,100,NA,NA,NA,NA,NA,NA
fan03,Fan 03,100,100,100,0,100,100,NA,NA,NA,NA,NA,NA
fan04,Fan 04,100,100,100,0,100,100,NA,NA,NA,NA,NA,NA
CONFIGURED TEMPS:
sensor,name,dow-uid,temp,temp-min,temp-max
HARDWARE TEMP SENSORS:
sensor,dow-uid,temp
Now my question is, why is it writing this, when "Enable temp monitoring and fan control" is unchecked, and how can I stop it? I tried setting the file to read-only, that just makes the cpu usage worse, because it tries to write to the file even MORE often!
Im afraid thats not the reason.
Writing ~1K of data to a file every 2.5sec will use next to no CPU time.
If the file cannot be written to (ie, it is read-only), an attempt to write to the file still only happens every 2.5sec.
Currently there is no way to disable updating of the stats file.
Back
