I'm using BGB320240-5a display with Raio8835p3n interfaced with dspic30f4011.
I've initialized display in graphics mode, but what I can see are vertical lines only.
Here is the code,
Here is the code,
void GLCD_w_cmd(unsigned char cmd)
DATA = cmd;
A0 = 1 ;
WRD = 0 ;
CS = 0 ;
delay_ms(10);
WRD = 1 ;
CS = 1 ;
//A0 = 0 ;
//delay_ms(10);
void GLCD_w_data(unsigned char data)
DATA = data;
A0 = 0 ;
WRD = 0 ;
//RED =1;
CS = 0 ;
delay_ms(10);
WRD = 1 ;
CS = 1 ;
// A0 = 1 ;
// delay_ms(10);
void HD_init()
delay_ms(50);
// CS = 0;
ADPCFG = 0xFFFF;
TRISB = 0x0000;
TRISE = 0x0000;
TRISD = 0x00;
RED =1;
// CS = 0;
delay_ms(50);
//RST=0; //display off
delay_ms(50);delay_ms(50);
RST=1; //display on
void GLCD_init()
GLCD_w_cmd(0x40); // MOV A,#40H ;System Initialize,With 8 Parameter
// CALL W_CMD
GLCD_w_data(0x30); // MOV A,#30H ;Interal CGROM+CGRAM1, 8x8 Font
// CALL W_DAT ;Single-Panel
GLCD_w_data(0x87); // MOV A,#87H ;8 Pixels Width
// CALL W_DAT
GLCD_w_data(0x07); // MOV A,#07H ;8 Pixels Height
// CALL W_DAT
GLCD_w_data(0x27); // MOV A,#27H ;Max Byte Number Of 1 Line:C/R=320/8-1=27H
// CALL W_DAT
GLCD_w_data(0x41); // MOV A,#41H ;TC/R:Length,Including Horizontal Blanking,Of One Screen Line
// CALL W_DAT ;17H=C/R+4<=TC/R<=76H
GLCD_w_data(0xf0); // MOV A,#0F0H ;Number Of Lines:240-1=0F0H
// CALL W_DAT
GLCD_w_data(0x28); // MOV A,#28H ;Width Of Display Line(Low Byte):320/8=40=28H
// CALL W_DAT // MOV A,#00H ;Width Of Display Line(High Byte)
// CALL W_DAT
GLCD_w_data(0x00);//1
GLCD_w_cmd(0x44); // MOV A,#44H ;Scroll Command,With 10 Parameter
// CALL W_CMD
GLCD_w_data(0x00); // MOV A,#00H ;Area 1 Start Address(Low Byte):00H
GLCD_w_data(0x00);
// CALL W_DAT
// MOV A,#00H ;Area 1 Start Address(High Byte):00H
// CALL W_DAT
GLCD_w_data(0x0F0); // MOV A,#0F0H ;Area 1 Display Lines:240=0A0H
// CALL W_DAT
GLCD_w_data(0x00); // MOV A,#00H ;Area 2 Start Address(Low Byte)
// CALL W_DAT ;160 Lines X 20 Chars=3200=0C800H
GLCD_w_data(0x00); // MOV A,#00H ;Area 2 Start Address(High Byte)
// CALL W_DAT
GLCD_w_data(0xf0); // MOV A,#0F0H ;Area 2 Display Lines:160=0A0H
// CALL W_DAT
GLCD_w_data(0x00); // MOV A,#00H ;Area 3 Start Address(Low Byte)
// CALL W_DAT ;0C80*2 =1900H
GLCD_w_data(0x00); // MOV A,#00H ;Area 3 Start Address(High Byte)
// CALL W_DAT
GLCD_w_data(0x00); // MOV A,#00H ;Area 4 Low Byte(Invalid)
// CALL W_DAT
GLCD_w_data(0x00); // MOV A,#00H ;Area 4 High Byte(Invalid)
//GLCD_w_data(0x00); // CALL W_DAT
// GLCD_w_data(0x00);
GLCD_w_cmd(0x5a);
GLCD_w_data(0x00);
//GLCD_w_data(0x87); //;--------------------------------------
// GLCD_w_cmd(0x5A); // MOV A,#5AH ;Horizontal Scroll Position
// CALL W_CMD
// GLCD_w_data(0x00); // MOV A,#00H
// CALL W_DAT
GLCD_w_cmd(0x5B); // ; MOV A,#5BH ;Define Screen Overlay Info
// ; CALL W_CMD
GLCD_w_data(0x0c);
// ; MOV A,#0CH ;XOR Mode,Two-layer composition
GLCD_w_cmd(0x5d);
GLCD_w_data(0x07); // ; CALL W_DAT ;Graphics mode
GLCD_w_data(0x01);
GLCD_w_cmd(0x4c);
// CALL W_DAT
// MOV A,#4CH ;Set Cursor Direction:Right
// CALL W_CMD
GLCD_w_cmd(0x59);
GLCD_w_data(0x04); // MOV A,#04H
//CALL W_DAT
void ADS_init()
{ //Initialize Display Address And Write Mode
int i; //;-----------------------------------------
GLCD_w_cmd(0x5B); //INIT_ADS: MOV A,#5BH ;Define Screen Overlay Info
// CALL W_CMD
GLCD_w_data(0x0c); // MOV A,#0CH ;XOR Mode,Two-layer composition
// CALL W_DAT ;Graphics mode
GLCD_w_cmd(0x46); // MOV A,#46H ;Set Cursor Address
// LCALL W_CMD
// LCALL W_DAT
// LCALL W_DAT
GLCD_w_cmd(0x42);
void ClearAll(void)
unsigned int i, j;
ADS_init();
for( i = 0; i < 240; i++)
for( j = 0; j < 40; j++ )
GLCD_w_data(0);
// delay_ms(10);
delay_ms(100);
void DisplayAll(void)
int i, j;
ADS_init();
GLCD_w_data(0xcc);
// delay_ms(10);
delay_ms(100);
