CrystalControl2 - 20060325
Status
Not open for further replies.
CrystalControl2 - 25/03/2006
It is recommended that you uninstall older versions of CrystalControl2 before installing this new version.
Not doing so may cause problems.
Version History:
25/03/2006:
- Fixed empty string INI bug.
- New kill_cc2 utility.
26/02/2006:
16/02/2006:
- Added user idle LCD dimming
- New screens
- Fixed screen loading bugs
- Added simple calc plugin
- Fixed many misc bugs
- New screens
- Manual updates
- New loadable screens
- Now supports item scrolling
- Many other smaller things
- First public release
See below for updates for this release
- 633 Plugin Update
633 Module Plugin Update.
This update fixes 633 contrast control problems.
Stop CrystalControl2 and then copy this new plugin into your CrystalControl2 directory overwriting the old file.
Status
Back
