JC's Water Cooling Worklog Screen Files
631 SCAB fan power 1-2:
631 SCAB fan power 3-4:
631 SCAB fan RPM's 1-2:
631 SCAB fan RPM's 3-4:
631 RivaTuner video card temps:
631 SCAB temps 1-2:
631 SCAB temps 3-4:
635 SCAB fan power 1-4:
635 SCAB temps 1-4:
635 SCAB pump flow:
Detail of fan Gif:
Detail of temp Gif:
Detail of pump Gif:
Detail of ATI Gif:
This is an updated ATI logo!
Author: JC634
Screen zip file: JC_SCAB-flow-ani.zip
Install Instructions:
Copy the gif files out of the zip to C:\gifs.
For the video card temps, you will need to have Rivatuner installed and running, and you must have its "Hardware Monitoring" enabled.
The Pump Flow screen is designed for use a Swissflow flow meter. If you are using a different flow meter that is compatible with CC2, you will need adjust the translation calculations accordingly.
Development thread: JC's Water Cooling Worklog.
Edit: New Pump flow screen for use with the latest version of CC2:
JC_SCAB-flow-ani-new.zip
