Fan RPM Test Screens (32 IDs) 634/5
Due to a request from a user needing new IDs for fans 4,5 and 6 in his system...... We proudly present 32 test RPM IDs only, so you can discover which are the working ones in your system. From this information a screen can be made up with the correct IDs used to give the RPMs you require.
These are seperate test screens with four ID`s per screen from 1-32. If one id=[E01] then it isn`t being sensed. If it has a number followed by RPM then it is being sensed. Read the Id (test) number (ID6 for example), open that screen with notepad and look at ID6 to get the true ID number 12145425852 for example.
Find the rest of the fans you have showing in Speedfan in the same way then all you need a is a screen making up with those ID numbers to see your correct fan RPMs.
Steve
Test fan RPM 1-4
  • speedfan fan rpms 1-4.zip
Test fan RPM 5-8
  • speedfan fan rpms 5-8.zip
Test fan RPM 9-12
  • speedfan fan rpms 9-12.zip
Test fan RPM 13-16
  • speedfan fan rpms 13-16.zip
Test fan RPM 17-20
  • speedfan fan rpms 17-20.zip
Test fan RPM 21-24
  • speedfan fan rpms 21-24.zip
Test fan RPM 25-28
  • speedfan fan rpms 25-28.zip
Test fan RPM 29-32
  • speedfan fan rpms 29-32.zip
well, what can I say? Whilst testing the next few batches of new screens an error was spotted in the above. It seems, using 'copy n paste' the top 4 ID numbers in each screen were not reflected in the bottom 4 ID numbers. If you`ve downloaded these already then you can manually make the changes or download again. Darrin, yours should be ok as you have the fans showing now. I`ve now uploaded the corrected screens, sorry for any inconvenience. :eek:
Steve
