diamondware
On firmware 1.5, a write to user flash following a read from user flash has difficulties. This is reproducible under the packet debugger. If you send command 3, wait for its ACK, then send command 2, an ACK will for command 2 will never arrive.
The panel responds with 21 bytes, the first of which is garbage (0x2e), followed by 20 bytes that look like an ACK to command 3, except the CRC is invalid.
It takes several resends of command 3 before a valid ACK is received.
Also, while attempting to find a workaround, the panel went into a state (after writing to user flash) in which no commands would have any effect.
We have some CFA633 with v1.3, and they do not show this misbehavior. Is this a known bug in the 1.5 firmware?
