Error cc2_config.exe only with HD44780 module
viguast
Hello, I apologize for my English. I connected a compatible LCD display hd44780, to your computer. With CrystalControl the display works well, I tried to install "CrystalControl 2", add the display 20x4 in "LCD MODULE SELECTION", then when I press the button "add new" in "screen selection", I quit an error file "cc2_config.exe ", this happens to me only selecting a form HD44780. I tried to select a module "HD44780 40x4" and everything is ok. Using "xpSP2, AMD ATHLON 64 X2 3800 +, 2Gb Ram." We put the files. Logs. Thank you.
The exact problem (HD44780 module) here with AMD Thunderbird 1GHz and XP Pro SP3. Any suggestions?:confused:
EDIT:
The module works just fine under CC1.
Thanks for reporting the problem.
There will be a new release of CC2 in the next week or so, ill try to have the bug fixed in that.
Hello everyone, I was overjoyed for the new version of CC2, but he appeared a different problem. When the service CC2service.exe gives the following error message:
szAppName : cc2_service.exe szAppVer : 2007.8.20.313
szModName : msvcr80.dll szModVer : 8.0.50727.762 offset : 00034c0b
I attach the logs.
Any update about this?!
I'd installed version 31.3.09 and have same problem. In fact, my display is a HD44780 40x4 ... with HD44780 works fine (part of screen obviously) but with HD44780 40x4 CC2 crashes when try to create new screen.
thanks
Back
