Variable Uint16_T in C language
S
shp
Guest
Hello..all
which datatype will be taken for the variable if one gives Uint16_t..??
How to convert Uint16_t to string in C language..??
Thanks in advance
Please do not post the same question in more than one forum :).
The Uint16_t is a synonym for "unsigned short", a 16 bit variable, also known as "WORD".
Convert to string?? You must mean create a string with the numeric value as text.
typedef unsigned short Uint16_t
Uint16_t value = 2057;
char text[32];
sprintf (text, "%u", value);
Result: text[] = "2057"
