Fabian Harder
In the data sheet for the CFAH2002A-YYH-JTV, you specify the voltage range in chapter “10. Electrical Characteristics” as 3.0V - 3.6V. At the same time, the maximum voltage is specified as 7V in chapter “9. Absolute Maximum Ratings”.
Is operation with 5V permissible or not?
A comparison with the data sheet for the Sitronix ST7066U controller used shows that it is suitable for both 3.3V and 5.5V.
I therefore assume that this also applies to the display?
Thank you!
Thank you!
