Looking for rFactor Plug-in
Is for the "session time remaining" this update? or you have added more...
Yeah, sorry about that... i realized that i hadnt said what had been changed later.
Yes, this is just an update for "session time remaining".
I did try to replicate the alt-tab problem, but couldnt do so :(
I couldnt see anything obvious in the code that would cause it either.
Natural1
Thanks for investigating this. Again, if I can provide any additional data to help track down the "esc from race session causes rF to crash" issue please let me know.
crobol
Try to do a shortcut to your rFactor.exe with this line :
"C:\games\rFactor\rFactor.exe +trace=1"
You must write your path game and a space between "exe" and "+"
This creates a log file named trace in your Userdata/log folder.
Maybe you can give this info to CC2admin...
Good luck
Worth a try... thanks for the info.
Bob Dunlop
Hey guys..is it possible to change screens with a joystick button or keyboard ?
If so..how:)
Thanks,Bob
edit.I see it is possible.I found it a couple pages back but it's all Greek to me:(
ZIP up and attach your CC2 INI files and ill have a go at it...
What key combinations do you want to do what?
Bob Dunlop
Thanks,the only thing I need is to be able to scroll through screens:)
The "x" key would be perfect :)
I will prolly have at least 4 or 5 screens when I'm done.
I already put the .dll file in my sys32 folder.
Thanks again!:)
Edit..actually if this can be done..I would like to have 2 keys for scrolling.."x" for scrolling forward and "c" for scrolling back through the screens because this will be controlled w/ a digital rotory encoder (knob) :)
And a key to turn the LCD off and on "v" key would be fine :)
Thanks,Bob
Sorry for the delay... to be honest, i actually didnt notice your reply :mad:
Attached is the two files modified for the events... c=next-screen, x=prev-screen.
There is no way to toggle backlight brightness with one key... two are required, one for on, one for off.
So ive left this for the moment.
If you want a description of what ive done to make this work, let me know.
Bob Dunlop
Ok..
I put the cc2_service.ini in the service directory...C:\Program Files\CrystalControl2\cc2-service
I put the cc2_keyboard.ini in the main directory....C:\Program Files\CrystalControl2
I have 2 screens w/ different names. "rFactor" and "rFactor2"
I restarted CC2..didn't work
I restarted my comp....still didn't work
I made sure I have the key_export.dll in my system32 folder..I do
Not sure what I'm doing wrong :(
Please advise :)
Bob
What version of CC2 are you running?
All of the CC2 ini, exe and plugin files should all be in the same directory.
Bob Dunlop
Well..I just tried putting them in my main directory and it just crashed CC2 and I had to reboot to get the screen on again :(
There has got to be a better way to do this.
I just uninstalled CC2 and then reinstalled a brand new clean install, tried it again and got same results :(
Sounds like a clean install is required.
Uninstall CC2, Reboot, then delete the CrystalControl2 directory (if it still exisit).
Reinstall CC2, reboot, then using the config app setup your LCD and load the simple Time-Date screen.
If that all works ok... go from there in remaking your rFactor screens.
Try using the CC2 Key Generator to generate a series on new ids too. I just reinstalled rfactor and mine didn`t work either. So I generated new ids, took the top two or any two at random from the list. Then pasted the top one into the keyboard.ini first location and then the second one into the second location. I matched these numbers in the cc2_service.ini ~This is where my key gen is....C:\Program Files\CrystalControl2\extras\random-id-gen
e.g. Keyboard.ini
[input00]
;id for reported event
id=2726938156
;key repeat rate in milliseconds
repeat=250
;key codes are in hex (Alt + Down here)
key0=0x002E
key1=0
key2=0
[input01]
id=2279952554
repeat=250
key0=0x002D
key1=0
key2=0
My first and second new generated IDs were used here with the ones in bold. First number to the top one and second number to the next one. Then this has to be matched in the service.ini Don`t use these numbers, use the generator to get your own, then make sure both places in bold have the same numbers in the same order, while CC2 is stopped. Do not change the id number in blue since this is the module id number and stops that module being addressed by CC2. Save, restart CC2 and check again.
e.g. Service.ini
[general]
use_trayapp=1
windows_start=1
dim_idle_time=0
dim_to_pct=15
[m00]
id=2756644296
module_name="Crystalfontz 634"
options=0
screen_sel=0
alt_enabled=0
brightness=80
contrast=60
dkc_disable=0
transition_random=1
transition_length=1500
[m00-event00]
if_type=1
if=2726938156
cond=0
to=1.000000
do_type=9
do=1.000000
[m00-event01]
if_type=1
if=2279952554
cond=0
to=1.000000
do_type=9
do=-1.000000
[m00-s00]
screen_name="rFactor"
options=0
alt_delay=10000
[m00-s00-r00]
options=0
scroll_speed=250
[m00-s00-r00-i00]
id=4118462336
options=0
length=2
scroll_speed=0
[m00-s00-r00-i01]
id=4154821602
options=0
length=0
scroll_speed=0
[m00-s00-r00-i02]
string="MoTeC"
options=1
length=9
scroll_speed=0
[m00-s00-r00-i03]
id=3821940652
options=1
length=8
scroll_speed=0
[m00-s00-r01]
options=0
scroll_speed=250
[m00-s00-r01-i00]
string="Fuel:"
options=1
length=10
scroll_speed=0
[m00-s00-r01-i01]
id=3864864804
options=0
length=6
scroll_speed=0
[m00-s00-r02]
options=0
scroll_speed=250
[m00-s00-r02-i00]
id=3381064960
options=0
length=0
scroll_speed=0
[m00-s00-r03]
options=0
scroll_speed=250
[m00-s00-r03-i00]
string="Race Time:"
options=1
length=10
scroll_speed=0
[m00-s00-r03-i01]
id=1190183954
options=0
length=5
scroll_speed=0
[m00-s01]
screen_name="rFactor2"
options=0
alt_delay=1000
[m00-s01-r00]
options=0
scroll_speed=250
[m00-s01-r00-i00]
string="MoTeC"
options=1
length=12
scroll_speed=0
[m00-s01-r01]
options=0
scroll_speed=250
[m00-s01-r02]
options=0
scroll_speed=250
[m00-s01-r02-i00]
id=1614579796
options=0
length=0
scroll_speed=0
[m00-s01-r02-i01]
id=2825512900
options=0
length=0
scroll_speed=0
[m00-s01-r03]
options=0
scroll_speed=250
[m00-s02]
screen_name="rfactor3"
options=0
alt_delay=10000
[m00-s02-r00]
options=0
scroll_speed=250
[m00-s02-r00-i00]
id=2105686085
options=0
length=0
scroll_speed=0
[m00-s02-r00-i01]
string=" "
options=0
length=0
scroll_speed=0
[m00-s02-r00-i02]
id=3946533252
options=0
length=0
scroll_speed=0
[m00-s02-r00-i03]
string=" "
options=0
length=0
scroll_speed=0
[m00-s02-r00-i04]
id=959122183
options=0
length=0
scroll_speed=0
[m00-s02-r01]
options=0
scroll_speed=250
[m00-s02-r01-i00]
id=1614579796
options=0
length=0
scroll_speed=0
[m00-s02-r01-i01]
string=" "
options=0
length=0
scroll_speed=0
[m00-s02-r01-i02]
id=1691275447
options=0
length=0
scroll_speed=0
[m00-s02-r02]
options=0
scroll_speed=250
[m00-s02-r02-i00]
id=3864864804
options=0
length=0
scroll_speed=0
[m00-s02-r03]
options=0
scroll_speed=250
[m00-s02-r03-i00]
id=1736574178
options=0
length=0
scroll_speed=0
