text to CFAF176220U-020T
hfbroady
I have the CFAF176220U-020T TFT display with the OTM2201A controller. I want to send simple Text to the display. The back light turns on, and this is as far as I got so far. The sample code that I have uses an SD card, but I don't need to display pictures or motion, just want to send text and change the color on the screen. Any help would be great, especially some very simple code. I'm using the PIC18f4520, with MPLAB and the MPLAB C18 complier (using C).
Port Assignments:
PORTC: DB0-DB7
PORTD: D0=/Reset, D1=/RD, D2=/WR, D3=RS, D4=/CS, D5= BL EN, D6=IMO
Here is what I have so far
#include pic18f4520
#pragma config LVP=ON
//#pragma config OSC = INTIO67
void write_command(unsigned char command)
CLR_CS;       // chip selected
  CLR_RS;       // set to write to the control registers
  SET_RD;       // not reading
 SET_WR;       // not writing yet
	LATD = 0x07; //chip selected, set for command (RS), (RD) not reading, (WR) not writing
  LATC=0x00;   // write the command to the port
	LATD = 0x03; // bring write line low, clock in the command
  LATC=command;// write the command to the port
	LATD = 0x19; // unselect chip, set for data
void write_data(unsigned char data_h, unsigned char data_l)
  LATC=data_h; // write the command to the port
  LATC=data_l; // write the command to the port
void display_color(unsigned char data_h, unsigned char data_l)
  unsigned int i, j;
  write_command(0x20);
  write_data(0x00,0x00);
  write_command(0x21);
  write_command(0x22);
  for(i=0;i<220;i++)
    for(j=0;j<176;j++)
      write_data(data_h,data_l);
void delay()
	int i;
   	for (i=0; i<3000; i++)
void initialize_display()
	LATD = 0x00; //Reset active low
   	delay();
	LATD = 0x01; //Reset off
	   	delay();
	   	delay();
  write_command(0x11);  // Power Control 2 (P22, OTM2201A Datasheet)
  write_data(0x00,0x18);// Booster circuits not started automatically, controlled through PON0-3
												// Generate VCI1, VCI1 = +2.58v
  write_command(0x12);  // Power Control 3 (P22-23, OTM2201A Datasheet)
  write_data(0x00,0x00);// Generate VGH VCI1 x 5 (13.75v) / VGL VCI1 x -3 (-8.25v)
												// Freq. of step up 1 = 1:4, Freq. of step up 2 = 1:2, Freq. of step up 3 = 1:4
  write_command(0x13);  // Power Control 4 (P23-25, OTM2201A Datasheet)
  write_data(0x00,0x63);// clock cycle of external (RGB) interface (as default, unused)
												// Gamma voltage (GVDD < AVDD (VCI1*2)-0.3v) 1100011 = GVDD Voltage +4.45v
  write_command(0x14);  // Power Control 5 (P14, OTM2201A Datasheet)
  write_data(0x55,0x6A);// VCOMG = 0 ( Amplitude of VCOM = |VCOMH-VCOML| ), VCOMH = GVDD x 0.8690
												// VCMR = 0 (VCOMH determined by VCM6-0), VCOMH = GVDD x 1.074
  write_command(0x10);  // Power Control 1 (P21, OTM2201A Datasheet)
  write_data(0x08,0x00);// Constant current in op-amp Medium Fast 1
												// Not in stand by, not in deep stand by
    delay();
  write_data(0x01,0x18);// Start booster circuit 1
 	delay();
  write_data(0x03,0x18);// Booster circuit 1 on, start VGH circuit
  	delay();
  write_data(0x07,0x18);// Booster circuit 1, VGH on, start VGL circuit
  	delay();
  write_data(0x0F,0x18);// Booster circuit 1, VGH, VGL on, Start VCL circuit
 	delay();
  write_data(0x0F,0x38);// Booster circuit 1, VGH, VGL on, Start VCL circuit
												// Start amplifier circuit, Generate VCI1, VCI1 = +2.58v
  	delay();
  write_command(0x07);  // Display Control (P17, OTM2201A Datasheet)
  write_data(0x00,0x12);// FLM output disabled
												// Gate output Enabled, Normally black
  write_data(0x00,0x1A);// FLM output disabled
												// Gate output Enabled, 8 color mode selected, Normally black
  write_command(0x01);  // Driver Output Control Register (P14, OTM2201A Datasheet)
  write_data(0x01,0x1C);// Decrement Address counter
												// 528x220 dots (176xRGBx220)
  write_command(0x03);  // Entry Mode (P16, OTM2201A Datasheet)
  write_data(0x10,0x30);// BGR (reversed color bits)
												// Increment automatically the address counter
  write_data(0x00,0x00);// FLM output disabled
												// Gate output disabled
  write_command(0x08);  // Blanking Control (P18, OTM2201A Datasheet)
  write_data(0x08,0x08);// 8 lines for the front porch
												// 8 lines for the back porch
  write_command(0x15);  // VCI Period (P28, OTM2201A Datasheet)
  write_data(0x00,0x20);//
												// Sn=2, Vcom1=1/2, Vcom2=2/1, RGB=16dot clock
  write_command(0x36);  // Horizontal Window Address 1 (P32, OTM2201A Datasheet)
  write_data(0x00,0xAF);// Set the horizontal start position of a window for memory access
												// 175
  write_command(0x37);  // Horizontal Window Address 2 (P33, OTM2201A Datasheet)
  write_data(0x00,0x00);// Set the horizontal end position of a window for memory access
												// 0
  write_command(0x38);  // Vertical Window Address 1 (P33, OTM2201A Datasheet)
  write_data(0x00,0xDB);// Set the vertical start position for memory access
												// 219
  write_command(0x39);  // Vertical Window Address 1 (P33, OTM2201A Datasheet)
  write_data(0x00,0x00);// Set the vertical end opsition of a window for memory access
												// 0
  write_command(0x50);  // Gamma Control (P34, OTM2201A Datasheet)
  write_data(0x00,0x01);
  write_command(0x51);  // Gamma Control (P34, OTM2201A Datasheet)
  write_data(0x02,0x08);
  write_command(0x52);  // Gamma Control (P34, OTM2201A Datasheet)
  write_data(0x08,0x05);
  write_command(0x53);  // Gamma Control (P34, OTM2201A Datasheet)
  write_data(0x04,0x04);
  write_command(0x54);  // Gamma Control (P34, OTM2201A Datasheet)
  write_data(0x0c,0x0c);
  write_command(0x55);  // Gamma Control (P34, OTM2201A Datasheet)
  write_data(0x00,0x0c);
  write_command(0x56);  // Gamma Control (P34, OTM2201A Datasheet)
  write_data(0x01,0x00);
  write_command(0x57);  // Gamma Control (P34, OTM2201A Datasheet)
  write_data(0x04,0x00);
  write_command(0x58);  // Gamma Control (P34, OTM2201A Datasheet)
  write_data(0x11,0x08);
  write_command(0x59);  // Gamma Control (P34, OTM2201A Datasheet)
  write_data(0x05,0x0c);
  write_command(0x0F);  // Oscillator Control (P21, OTM2201A Datasheet)
  write_data(0x0F,0x01);// Freq = 453kHz x 1.29
												// Oscillator on
  write_data(0x00,0x17);// FLM output disabled
												// Gate output Enabled, Normal display, gate on, vcom on, display on
  write_command(0x22);  // GRAM Data (P30, OTM2201A Datasheet)
void main ()
             int loop = 1;
             initialize_display();
	while (loop == 1)
		display_color(0xff,0xff);  // change the color of the display to black
Thank you
Heath
(moderator adds code formatting.)
I just took a quick look at the data sheet for this display, and it seems that this is a graphics-only type of controller. That means you would have to draw the text on the screen as bit patterns, using your own code, since there is no "text mode" or CGROM in the controller.
A lot of the TFT displays have remarkably similar interfaces and instruction sets, so you could use some of the sample graphic/text code that is posted on these forums. Here is an example thread that has some code for the CFAF320340, but it is a simple matter to change the defines for the screen dimensions.
You will have to also have fonts as part of your code (i.e. the bit patterns for the characters). Those are included in the sample files (the newest files are in post #28 of that thread).
https://forum.crystalfontz.com/showthread.php?6637-Text-graphic-C-code-for-CFAF320240
Actually, I found that I do have the CFAF176220 display, and have written some test code for it, but it is not posted here, and is actually based on the CFAF320 code, so I'm pointing you to the posted code for starters.
BTW, what I gather from your post is that you can't see anything on the screen yet... is that true? That's the first thing to fix, before trying to write text. Also, regarding putting characters on a graphics display, you will need much more than "very simple code".
hfbroady
Yeah, when I power the TFT up all I see is back light. I'm not even sure how to get anything to display onto the screen. I don't have a storage device like a microSD card or anything. So not really sure how this will work. Is there a way to change the color with some code. I saw the datasheet and it's doesn't say where or how to change the color.
Also where In the datasheet did you see that is said graphics only.
I need to get better at reading datasheets.
Heath
That's what the code is for, but I suppose you knew that.
Don't need external storage. The program is burned into flash memory on the CPU.
The way to change screen color is to write pixels of the color you want, to replace the current pixel color. To fill the screen with a new color, you'll have to perform 38720 write operations (176 * 220). The color is contained in the data that you write.
Also where In the datasheet did you see that is said graphics only. I need to get better at reading datasheets.
The datasheet doesn't explicitly say "graphics only". It also makes absolutely no mention of any built-in text mode, so you have to draw the conclusion yourself.
As I look a bit more at your test code, I see that it can't possibly work. I am curious about this:
There is no signal on the interface called IMO. There is a signal called IM0 on the OTM2201A controller, but it is not brought out to the interface.
Anyway, your write_command() and write_data() functions have some serious problems. The /WR signal clocks data in on the rising edge; you don't bring the /WR signal high at all while data is on the bus. Also, at the end of the functions, you leave both /RD and /WR low, which is a bad idea.
I suggest you look more closely at the sample code in the data sheet, and the files in the thread I referenced, to see that the /WR signal needs to be taken LOW then HIGH for each data byte on the bus.
Also, in the initialize_display() function, your /reset signal seems to be inverted, although this will be corrected by the first data/command write.
If these fixes do not produce any results, then we'll have to look more closely at your code.
hfbroady
The code that I got was write of the crystalfontz website. So I just copy and pasted that code. I will continue to work at this. I learn new code better when I have a WORKING examples to look at.
Based on your sample in the first post, I can see that is not true. You took working code and commented it out:
and substituted non working code:
That is why your program does not function.
Yes, well the working example is there for you to use. If you wish, I can post MY version of "working code" also, but it is so similar to what you already have that it may not help.
If you have updated code that you want critiqued, post it, but please wrap it in "code" + "/code" formatting (change the quote marks to [ and ] characters, or go to the advanced editing option and use the "#" tool to add the code tags to your text).
