Freddy warbird
Hello. First post. First problem. Anyways, I discovered the Crystalcontrol2, and this forum last night as I have been attempting to learn how serial port, and LCD communication works, so that I may learn something before I explore this further. Noob Alert! I picked up an 5x7 dot 16x2 character LCD module from a local electronics surplus house. It is this one here.
http://201.232.58.13/pub/internet/nuevo/cm162b.pdf
I followed the instructions on the CC2 site as if it were the generic 14 pin + backlight using an old printer DS25 cable. I believe it's wired correctly as I get a nice default TEST screen of the 16x2 5x7 led's coming from the front panel. The module is plugged into my old Compaq Armada E500 850 laptop running a fresh install, and fully up to date version of Windows 2000 professional sp4 32bit. The port setting in the Bios is set to Bidirectional.
I installed the latest version of CC2 using Opera brower as the downloader, and followed the instructions. It asked me to re-start, and upon coming back to the desktop, the little CC2 icon went blue. I configured my model to the HD44780 port 0x378. I also downloaded the Screens files, cause they are missing, and unzipped them to the CC2 directory. I used the *.2002, under file name and was able to see files to load. I loaded a 12 hour clock just to see if something would come up. File name set to *.0000 are blank, or the folders appear empty. Don't know why that is, and I realize that the 5x7 dot module that I have, may be an odd ball size for CC2, or for what file are in the program.
Here's the problem. The moment I re-started the CC2 application, I got an Error, and have been getting this error every time whether I attempt to restart the CC2 service, application, or on a computer restart. It just won't run. It ran the one time on the very first computer reboot, and that was it. I can go into configure, but that's about it, and the CC2 icon is always red now.
Windows event viewer gives me these three error reports.
Source CC2_showgif
ERROR 20100429-022025-0. 001672s load_settings #291:file"C:\gifs\clock_logo_anigif not found or not valid GIF,skipping section
ERROR
Source CC2_keyboard
ERROR 20100429-022025-0. 002002s load_dll #267: could not load key_export.dll
Source Service control manager
The CC2 service terminated unexpectedly. It has done this 7 times. no attempts to restart. no action taken Bla bla bla.
Here are the log, and ini file to look at. I hope I zipped it correctly, and thank you for at least reading about my issue. Thanks again.
Source CC2_showgif
ERROR
Source CC2_keyboard
