Hello, I apologize for my English. I connected a compatible LCD display hd44780, to your computer. With CrystalControl the display works well, I tried to install "CrystalControl 2", add the display 20x4 in "LCD MODULE SELECTION", then when I press the button "add new" in "screen selection", I quit an error file "cc2_config.exe ", this happens to me only selecting a form HD44780. I tried to select a module "HD44780 40x4" and everything is ok. Using "xpSP2, AMD ATHLON 64 X2 3800 +, 2Gb Ram." We put the files. Logs. Thank you.
