Help making RSS work
Grentz
Help with RSS plugin.
I am looking to make a plugin that reads the RSS data from a RSS feed on my tivo.
Here is a sample of what the code looks like from the Tivo:
<item>
<title><![CDATA[On Deadly Ground]]></title><link>http://192.168.0.70/showing/67246/12</link>
<description><![CDATA[An oil-company trouble-shooter must blow up his employer's unsafe refinery to protect Inuit land in the far North.]]></description><guid>http://192.168.0.70/showing/67246/12</guid>
<pubDate>Mon, 18 Dec 2006 05:35:00 GMT</pubDate>
</item>
<item>
<title><![CDATA[The Oblongs]]></title><link>http://192.168.0.70/showing/70854/12</link>
<description><![CDATA["Father of the Bribe" A bribe for the mayor ends up in the twins' hands.]]></description><guid>http://192.168.0.70/showing/70854/12</guid>
<pubDate>Mon, 18 Dec 2006 06:30:00 GMT</pubDate>
</item>
I have dug into some of the included RSS plugins to see if i can work something out and it seems that all the plugins use the regex= lines to determine what is shown from the feed. I have gotten the feed to show up by using the regex line like this:
opt09="regex=(?is)<item>.*?<title>(.*?)</title>.*?<item>.*?<title>(.*?)</title>.*?<item>.*?<title>(.*?)</title>"
The problem ist hat each item also gets the extra bit of information <![CDATA[ and ]]>. I really only want the information int he middle of that (and I do not need the pubdate or description info). Is there someway I could do this?
I have been looking at how to use regex but have not found any good easy guides on it.
Grentz
Grentz
Ok, sorry, nm
I found a workaround by changing the RSS generator on the Tivo so it did not have that extra info.
I think i was having problems as the [ is used in regex for other things even though i wanted it to find and disregard it.
